Hi. I am rebuilding my pump and replacing impeller and wear ring. Working on 1996 Sea Doo GSX.
I did notice when disassembling pump (from hull PUMP SUPPORT bracket) that there appears to be a rubber boot or perhaps its part of the wear ring that has stuck around pump support.
Is it an actual rubber boot or the wear ring that has stuck on through the years?
Hope this makes sense. Thanks
Carl
Carl
