Thanks Pale Rider, good info. I plan to do some gps testing and some hole shot testing first and get some baseline numbers. I'm not even sure what I have in there. I assume they are stock, but not sure..
It`s never a good idea to mash the throttles on these old boats, so just be careful when trying to launch full blast... everything is old, and even when parts have been replaced the weak link will let go, not a matter of if, a matter of when...
if everything isn`t perfect, like blade edge, wear ring clearances, pump condition, etc etc you will not get an accurate measurement. but close...
even steering nozzle mis-alignment will scrub speed...
you really can`t expect to gain a lot with these boats. Most people go the other direction and are more concerned with bottom end pull for skiers and tubing. Like mentioned before you`ll sacrifice some bottom end for more speed, maybe a tick more is all that`s expected.
The bottom line is the aftermarket impellers are way more efficient at processing water than the OEM regardless of who made them. BRP`s spec aren`t to bad considering the multi use platform and the compromise associated with it...
We also cruise a lot, anywhere between 4700-6200... so top end gain really doesn`t matter unless your goal is to constantly race the boat...
and then again with older boats, I`m sure there is water in the inner layers of the hull and that equates to more weight compared to when new...
there is more of a "feel" and seat o the pant gain in jet ski`s compared to boats when using a different brand/pitch impeller. lighter, more responsive and less wetted hull is a major dramatic difference. IMHO lots of folks get this cornfused coming from ski`s VS boats...
One guy nailed it with that twin 951 screamer somewhere here on the forum... More speed equates to a lot more useable horsepower/torque and following up with a tuned impeller...
