So I was on my honeymoon and took my 210 seadoo challenger to muskoka (great spot in Ontario). On my second last day we were in shallow water and sucked up some small sticks into the pump. Thought they just cleared after driving a short distance (I thought it was seaweed). Docked for the night. Next morning heard real bad high pitch noises from port side motor. Shut it down and put it on the trailer. Found a small stick in it. Got the stick out and back in the water same noise. Pulled it back out and took the pump off. Bearing was totally destroyed. I've got all new parts to rebuild my pump but here's my concern. There was a fair amount of water in the hull.
I'm concerned this may be a carbon seal issue. The impeller shaft was kinda crooked and as I mentioned the bearing destroyed. The drive shaft looks perfectly in position.
Could also have been my new wife putting the drain plug in sloppy. She had never done it before and was trying to be helpful.
I checked the hoses nothing is cracked or lose. Any thoughts?
