pump oil changing help
Welcome to the seadoo forum chris j. Here is some informatin on the jet pump oil;
If you look into the nozzle in the rear of the ski you will see a cone with 3 screws and an oil filler allen screw.
To change it.
1) take off 4 13 MM bolts holding nozzle and 10 MM bolt holding steering.
2) get something to catch the old oil in, drain pan margarine cup etc.... (don’t forget the nose plugs, the oil stinks to high heaven)
3) remove the 3 8 mm bolts holding the cone on.
4) pull the cone and drain the oil out. Prop the front of the trailer up as high as you can to get most of it out.
5) Inspect the rubber "o" ring and if it is good apply silicon and reinstall the cone. Make sure the allen fill plug is on top.
6) lower the front of the ski and add oil to the cone. when it is full, take a brake and have a drink. There is air in the cone and when you go back you will see that it is low. top it off and take another brake... do this until the fluid does not lower again. I often start the ski for a few seconds to make sure oil is all the way worked into the bearings and all the air is out.
7) wipe silicon on the set screw and screw it in (be sure not to run it all the way into the cone. just deeper than flush is fine. let it sit 24 hours to cure the silicon and put the nozzle back on.
8) Use Sea Doo 75w90 GL5 Synthetic Polyolester Oil
If you want you could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and privet use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too.
Karl
It's really easy. I was nervous doing this too. But once you are sitting behind it, and looking at all the parts, you realize it's VERY easy to work on!!
Done. That was easy. As far as other lube maintenance is it just the cables and the on zirk fitting in side?
I am a new owner of some 98 GTIs. The venturi on one of them is gone. I called a "shade tree" technician and he said that many folks take the venturi off to increase speed and as a result it is not necessary. I wanted to check with you all before I tried using the ski. Any comments? Thanks,
