pump interchangability
LawnDart
Will 1995 speedster pumps fit my 1998 sportster? The 140mm pumps visually look the same but are different part numbers.
sort of.
You have the "Newer" style hull mounts. So, it should line up... but you will have to change the water pickup. As long as you have the old pats from your Sportster... it should work out.
Yes my sportster pumps are intact but I plan on rebuilding the older brass speedster pumps with aftermarket impellers. Then I would have my sportster pumps as spares. So it sounds like I need to get some water pickups.
Thanks that is very helpful.
