N NautiNauti New Member Apr 2, 2009 #1 Does anyone have pic of a pump gauge tester they have made or where is the best place I can go buy one?
kustomkarl Premium Member Premium Member Apr 2, 2009 #2 You need a "Pump Gauge Tester"? Do you mean a feeler guage to check the wear ring/ impeller clarence? It's just a 12 inch feeler guage. The manual shows pictures if you browse the wear ring section. Karl
N NautiNauti New Member Apr 4, 2009 #3 HI Karl, The manual show one to for checking the pressure at the carbs.
rookie101 Premium Member Premium Member Apr 4, 2009 #4 Pop off/leak tester If your talking about a pop off/leak tester, have a look at this thread that Nswillin wrote. Aaron http://www.seadooforum.com/showthread.php?t=12624 Last edited by a moderator: Apr 4, 2009
Bills86e Premium Member Premium Member Apr 15, 2009 #6 Chase it down: http://www.seadoosourse.com/mikunitests.html
Chester Premium Member Premium Member Apr 16, 2009 #7 When you pressure test your pump, don't go past 10 psi. I always test them at 10 psi. after a rebuild, I pressure test the engine at 10 psi also. Chester
