For the second year in a row I have had the jet pump cover leak, which has destroyed the bearing. All the grease must get washed out. There was no grease inside the cover when taken off.
Last year it happened around mid season, this year was the first time out. There was a crack in the cover this year. Not sure if water was inside over the winter. I should have checked the cover before storage but thought that because the bearing was changed only a month before it wouldnt be an issue:facepalm:. The bearing was changed under warranty last year.
If the cover was pressure tested after the dealer installed it shouldnt there be a cap at the tip of the cover?
Is it common to get a little water inside the cover?
Do anyone know if this would be a warranty issue again.
BTW I have a 2010 180 Challenger 255hp with 52 hrs
