brevard2002
2002 240 efi,
son borrowed boat, called to say right from dock it was smoking awful and not enough power to get on plane. when he got it home and started it to flush, he said sludge coming out exhaust ports. Boat was fine two weeks ago. I think its way too rich. the air and water temp sensors okay, fuel pressure regulator is 2 months old. I have new ECU that doesn't use TPS.
One idea was the diaphragm on the pulse pump is ruptured and fuel is being sucked in.
Looking at parts diagram it has a lot inside it, and I would guess when it is removed from block it will all come apart and so have think having a new gasket/diaphragm kit on hands is wise.
Anyone every pulled or worked on the pulse pump?
also I need to check leak down rate of fuel rail to be sure injector is not leaking.
