OK... now we are getting somewhere.
SO.... if you hook up a "Mighty Vac" (hand vac tool) you can drive the fuel pump and get fuel up the hose? BUT, the engine won't drive it? BUT, the engine has 150 PSI compression.
If that's right... then there could be crank seal leak on that engine. Basically... the pressure/vac being produced by the piston is not being held in the crankcase.
OR....
your rotary valve isn't spinning, or it's very out of time.
A quick test for that is, put a little mixed fuel directly down the carbs, and see if it will start. If it doesn't... then pull the carbs, and verify the valve.
