kilgorekb
While holding the steering wheel to right at about 60 degrees, boat moves along 12 o'clock axis while bow is pointing toward 11 o'clock.  This happens both at idle speed and high speed, with both engines at same RPM.  Very difficult to load on trailer when it won't go the direction it's pointed.  It was like sliding into home plate with a hard right at the last second.
I've read through other threads trying to get an idea. Just checked nozzle alignment and they are aligned with each other. Can someone clarify what I should check next?
What changed since last outing? I cleaned the RAVEs.
