the easiest, safest way is to remove the pumps, and the driveshafts.
There is JUST enough room to do it without removing them... but there is a HIGH probability that you will bend the driveshaft, or mess up the hull, at the D-shaft seal. Personally, I remove the pumps. It takes less time to do that... than it takes messing around the other way.
