ok pulled the boot back pulled the c clip off then pulled everything out, first question, is the carbon seal suppose to be so loose on the shaft, second is where the carbon seal touches the back of the stainless peice where it seals out the water? so do i need a new stainless peice also? i got everything else, the shaft doesnt look bent when i spin it but one side of the carbon ring had a groove in it and its way bigger than the shaft, also my oil line is leaking under the tank from the big line is that just a grommet? im gonna be replacing my oil filter and fuel filter when im done with this driveline stuff and welding my rideshoe back on,
