95SeadooHxr
neither of the carbs where synced one lsa was 2 turns out other about 2 1/2, HSA was out 1 1/2 turn out other 1 3/4? would these be the reason i am having the problem below?
well it starts in the water, when i go to accelerate it doesnt feel boggy bud it just doesnt want to go no matter if i push the throttle all the way or just a bit it jsut gradually gets up to speed which is like 25mph. then it jsut seems like i have to sit at that speed and play with the throttle around 3/4 way down to get it to open up. If i mat it all the way it will bog and not move. it will also only go partial wot for a few seconds and then falls on its face, and just turns off in the middle of going. My last run out i was able to get it going at partial WOT for about a minute and jsut fell on its face. seems once it falls from going WOT i have to sit their and play with it to get it going decently again. finally got back to the dock pulled the plugs the lower one ( towards seat) looks mint nice chocolaty color, the top one looks rich, very dark like a dark chocolate. also compression is 140 on both. i really need some help guys i am going back out friday to play with this thing! IS it an airflow problem? fuel delivery/carb?
i also forgot to mention that it has an after market ape pipe and a increased rev limiter box in the ecu box. with the exhaust will jetting be different? also would a leaky exhaust cause an issue, or does it sound like a carb issue?
