Prop tight to turn
NEZZA
Just doing a pump rebuild on my pump for a rxt300
Torqued the main nut down but when I come to Do the prop you can not turn the houing at all it as if it is way too tight. Slacken it off and it will spin but it will not be set at 92lb then
"come to Do the prop" ? Suggest you disassemble the pump and check the parts breakdown to make sure you've put all the pieces in the correct order.
