My DOO Don't
Purchased a 1996 Seadoo Challenger several years ago. Previous owner claimed drive shaft, and drivetrain components had been professionally replaced the previous year, and had service invoice supporting this claim. Used the boat several times that summer and it performed well. Early in the fall took it out to use it again. Performed well for first part of day. However, it very suddenly developed an issue where it had throttle, but no thrust. Checked for debris in jet pump, but nothing. Ended up having to be towed in.
Long story short, life got in the way, and the boat sat for a few years. Finally got the time to mess with it this year. After doing some research and digging around in the boat, decided to rebuild the drive shaft and jet pump components. Purchased the shop manual. Have successfully removed jet pump and all clips, o-rings, and clamps related to drive shaft. However, I am unable to remove the drive shaft itself. It appears as if the drive shaft was replaced without the rubber bumpers, at least on the end by the impeller (I can, of course, not see the other end). At this point, the drive shaft will push in to a point where it seems to go forward past the splines on the pto. In this position, the drive shaft will spin freely. If the drive shaft is maneuvered back toward the stern, I can feel the splines engage again and the drive shaft will not spin freely. If the rubber bumper was not reinstalled when the drive shaft was replaced, would this be the scenario? In any event, the drive shaft will not come out, even when the splines are aligned. Has anyone else experienced this issue? Does anyone have any suggestions for removal of the drive shaft in this situation? I greatly appreciate any help that can be provided!
