Hey,
Took boat on first vac last week. Got 3 good days out of it. Then needed to fill tank and figured i would add a gallon of the oil to the resivore to top it off. Left the dock and was 15 to 20 minutes out and engine locked up. Pulled engine cover, opened top resivore and it was empty, then saw i had left the main resivore cap unscrewed back in place after adding oil. Am assuming that one mistake killed the engine. Will add pictures later of the pieces of the enginge block i found sitting next to the engine, 8 or 9 approx.
It has/had the M2 Merc 240 EFI 2001 - 2002. I am thinking the option will be to buy a complete motor (Powerhead) to replace it. From the documentation i have it looks to be not a lot to remove the old one and drop a new one i place. Would like to know if this is correct.
Would also like to know if i should replace it with the newer 240 EFI or even the 250 Optimax. Would either of them be a straight replacement for the one i have or should i stick with exact same model?
Appreciate any advice or suggestions.
