bigJake
I have a problem with one of my water toys. Not a jetski, but it's got an engine and a water pump so I figured you guys would know.
[TABLE="align: center"]
[TR]
[TD="colspan: 2"]Porter Cable Model #: PC2525SP
2500 PSI PRESSURE WASHER, 2.5 GPM 5.5HP HONDA GX ENGINE
There is a slow drip of water from the pump head (Part #25) but the bigger problem is that there is slow leak of water into the pump oil (pump NOT engine) and oil/water mix is leaking out the oil fill plug (part #50). There is a small vent hole in the plug the oil is leaking out thru.[/TD]
[/TR]
[/TABLE]
http://shoppingcart.msservicecompany.com/msservice_net/product_files/PC2525SP/d25108.pdf
I ordered the Water Seal Kit (Part D). Does that seem correct to stop the water leak into the pump oil or do I need the oil Seal kit (Part C) ?
Also, one of the pump pistons has some very mild surface rust, how should I clean that off so that it doesn't ruin the new seals. I wasn't sure how aggressive I could get without creating minute scores that would leak. is 600 grit sandpaper OK?
[TR]
[/TR]
[/TABLE]
