kgray61340
Hello started my pressure test today :thumbsup:
Started with engine cooling system and pressure held good there :thumbsup:
Next was Bottom End and Top End It would leak down and I checked everything and everywhere with soap and water mixed and couldnt find a leak . Directions say then to block off inlet oil nipple to rotary valve and the return line for the rotary valve and see if it quit leaking down . And thats what it did ! :cheers:
Next was the Rotary valve shaft testing This is where it was leaking down at a good rate I checked the Plug for the Rotary shaft in the crank case no leaks .
Tried these two below : and the gauge show no noticable difference when the spark plug was loosened . same amount of pressure drop
Remove PTO side spark plug. If pressure drops, it
indicates a defective PTO side crankshaft inner
seal.
Remove MAG side spark plug. If pressure drops,
it indicates a defective MAG side crankshaft inner
seal.
sooooo I removed rotary valve cover and checked the rotary valve shaft seal and couldnt find a leak there either
sooooo I believe that meens that the crank case halfs is where my leaks are and the reason i get black oily plugs
Gonna start by removing magneto flywheel tommorrow and PTO flywheel and then check manual for next move
one more thing i took a video of the rotary valve splines and i could turn it back and forth three splines at a time with out the crank even moving dont know how to get video on her yet so any comments would be apprieciated :cheers:
http://www.youtube.com/watch?v=Vt2aCks6i08&feature=youtu.be
seal.
seal.
