hello all, i have a 2000 speedster 240 efi gen 1. the boat has a factory rebuilt engine as the original engine was smoked due to the oil pump failing. the previous owner bypassed the oil pump and went with premix. question is, will it smoke more with premix rather than the oil pump? i know that smoke on start up is normal, i wish i had taken a video before i pulled it out of the water. smokes alot at start up, and amytime i run at idle for more than 2 minutes it starts again. how hard is it to revert back to oil pump, and is it worth it in your opinion? also will it smoke more if i have the ratio wrong with too much oil?
