00Challenger2K
Question for the 240EFI experts:
I bought a 2000 Challenger 2000 last November that had some issues with the 240EFI, M2 package. Engine issues at the time were, no spark in 2 cylinders. So, I replaced the trigger module. That resulted in getting spark at all 6 plugs!
After running the witches brew through the engine & performing the prescribed winterization steps, I then replaced all of the spark plugs, the water separating fuel filter (and sensor), the inline fuel filter by the small electric fuel pump, and the port side head temperature sensor. I also completely drained the fuel tank and oil tanks (main & reserve) and let them remain empty over the winter. This spring, I filled up the respective tanks up with fresh (non-ethanol) fuel and Mercury 92-858027Q01 oil. After re-installing the battery and changing the lube in the jet pump, the boat started up just fine. It idles great and runs great at all speeds - well...just about all speeds. Here is the issue:
If view the throttle with 8 imaginary positions with position 0 being idle and position 8 being WOT, I am experiencing a problem at throttle positions 6-7. If I'm running at WOT about 6000rpm and 55MPH, and I back down the throttle just a little to the 7 or 6 position, the engine drops down to like 2000 rpm and the boat comes off plane. The engine sputters and surges if you leave the throttle at this position. It does not die. Just runs oddly with much lower rpm. Now, if I pull the throttle back to the 5 position, engine rpm peaks up again (like about 4000rpm) and the boat gets back up on plane and runs great.
This situation happens if I am coming from throttle position 8 downward to 7-6 but it also happens if I ramp up slowly from position 0. Positions 1, 2, 3,4, & 5 all work as expected....Engine RPMs rise and the boat goes faster and faster. UNTIL you get to position 6-7. There, RPM's drop to like 2000 again and boat slows down and surges. But pushing past that to position 8 hits WOT again and RPM's rise to ~6000 again and boat runs great moving along at ~55MPH.
So, what's going on? What engine component(s) could cause this? I already replaced all of the common-cause and tune-up components, so I'm baffled. Could this be an adjustment issue...like timing adjustment or TPS adjustment?
I do have the mercury service manual as well as the manual used to train Mercury service techs on the 240 EFI engine, but I don't have access to the expensive Mercury diagnostic plug-in tools, so I'm hoping someone here can shed some light on what may be going on in my situation.
Thanks, in advance to anyone who can help me figure this issue out.
