Compressor hp
The compressor in your Doo is designed for power by forward momentum.  It acts similar to a jet aircraft engine.  The more pressure you provide to the inlet by forward momentum, the faster your gonna go. This is easily seen in the jet pumps by nosing your Doo into a dock or embankment.  Give it WOT, note the amount of thruse coming from the nozzle.  Then take it out on the river and do WOT, look back at the nozzle. Notice the difference in the nozzles output.  You should see a big difference.
Well, the same is true in sharp turns.  When you turn, the forward push into the pump is changed and now trying to come in from the side as your direction changes.  This can be seen by a simple test too.  Accelerate in a straigt line but maintain a speed less than wide open throttle, say 30 mph.  Then, make a turn (not a super tight one though) and note the speed beginning to drop off.  When that happens, increase the throttle.  You'll notice that by increasing the horse power to the nozzle you can keep up with that set speed.  Well, if your already at WOT when you go into that turn, you have no power left to give the engine to keep it at the speed you were at before the turn was initiated.
This is true in almost any type of boat or PWC.
