Hello fellow Merc fans! 2000 240EFI Islandia smokes like a chimney, with rough idle. But I think I found the culprit! Looks like the oil rod is hanging up on the VST.. if my thinking is correct, it would then be running oil in at 50:1 ALL THE TIME. Wanted to ask a couple of you if my assessment makes sense be for I break out the victory cigar. See attached picture. Looks like I need to put a couple washers behind the VST mount to clear interference. No matter where throttle was set, rod end was in this position. A small bang on the VST, and she snapped back down..
