hypersniper2010
i have a 96 mercury sportjet 120xr motor. when i bought it i was told it had no spark. bought it and threw a battery in it and tried to crank it and it wouldnt crank. so i pulled the plugs and it still wouldnt crank so i pulled the head and there was a small piece of metal wedged between the piston and and cylinder wall so i thought it was a bad ring so i split the block only to find the crankshaft had snapped right at the top cylinder and the small piece of metal was from the crank. could this have happened if someone tried to start it while it was already running? or a backfire cause the ride plate is blown off on 1 corner. no obvious other damage. impellar and jet drive are all 100%...
only other thing i noticed was the flywheel was bent slightly and 1 tooth on the starter is chipped pretty good.
any other ideas ???? im open to any and all. i already bought a new crank and it will be shipped tomorrow and i dont want to break it again.
thanks
thanks
