problem with that is, is that, yeah they're the SAME color, but NOT the same "gram'.
The stock spring, in your application, is around 70/80gram, where the one you installed is 95gram.
Springs dont go bad, unless they're rusted or tweeked by "misude" in rebuilding. So, i'd re-install the stock ones. If you dont have tthem, then install the "black" spring (80gm), this will put you within range of the stock ones.
