link81
rebuilding the carbs on my 951.
using genuine Mikuni kits. Finished the first carb, tested pressure.... 12 psi. weird.
made sure the seats were wet, using original springs. tried swapping springs from the kit, and lever arms. same result.
put that cab off to the side and rebuilt the other. pop off pressure? you guessed it 12 psi.
both are dead even, on the money.
Shop manual says 19-23 psi.
is 12 close enough? should I mess with bending the ams a little? Do I need to order new springs?
