I'll weigh in here.
I have been running pre-mix in my Speedster for 5 seaons now, going on the sixth. I run one set of plugs all season long and have NEVER fouled one yet. I winterize with those plugs then start up with them and after the fogging oil is cleared out, I put in a fresh set of gapped NGK's for the season. I do travel in areas with no wakes for 5-10 minutes at a clip. The MOST I have ever gotten was a bog as I pasted it coming out of a 10 minute no wake, ran it a 7K for a minute or so and the next no wake, no bog. I mix 40:1 with XPS-II, it's expensive as all get out. I figured if I was out of gas and with XPS-II and mid grade gas at $3.89 a gallon, a fill up will run me $213.00-not a typo! I get a tad bit of smoke on start up, and not enough to bother me at no wake speed, I'll put it this way, my wife hates the smell of gas and she never complains about it.
As far as mixing at the pump--cake work. I carry a gallon with me and a Seasense bottle. You fill up to an even amount the look at the bottle and fill it to that line. The most work you need is to divide into equal parts. So you would find the 40:1 column, then if say you got 20 gallons, I would break that down into 4 equal parts and fill to the 5 gallon line and do that 4 times. Each time I put an amount in the tank I take a dab of oil and put it on the boat--to keep track of where your at, then just wipe it off. I always fill up on land so by the time I get to the ramp I'm all shook up in the tank, but if your filling up at a marina, by the time you get moving you'll be good to go.
Leave the tank and sensor and fill it so the sensor works so IF you crank seals go or a line were to break you'll get a warning.
Don't forget to take the oil pump drive out of the front cover. The cover needs to be removed to remove the drive. And don't forget to cap the injection nipples on the R/V cover.
Good luck!
Here's a link to the bottle:
https://www.google.com/search?q=Sea...56,d.dmQ&fp=e1c7ac95cf77e9dc&biw=1024&bih=677
