Newbie question!
I (newly) own a '00 LRV with a 947 purchased with 128 hours and well maintained. After a few months of flawless running, this week I was in the middle of a ride and half the engine just "went away". I was cruising a 50MPH and could not get over 25MPH, RPM's would not come up and I thought I lost a plug wire or such. I had spare plugs on board and swapped them on the water, and found the forward plug was fouled comletely closed. The new plugs solved the problem until about 45 minutes later when the exact same thing happened and required me to swap out another front fouled plug with my remaining clean one to get home. I pulled the boat and did a compression check to see if a bad ring may be the culprit but she's healthy at 135 and 145 PSI with the fouling cylinder the tighter one. Aft plug looks fine.
What next?
Thanks
What next?
Thanks
