Ok.. I bought a '00 RX (951 carb) from someone used. I'll admit he was a bit shady so I wouldn't be surprised if he hid something from me. I took the ski out for the first time friday and ended up getting towed in..and i'm stumped! heres what happened:
It had no battery so I installed a brand new batt, new gas and plugs. At first it ran great out of the water on hose, then in the water it was bogging down and stalling at low throttle, If I feathered the throttle a bit it got alot better. So, then it's running good, with an occasional spit n sputter so i'm thinking ok great i'll just tune it up a bit, clean the carbs, etc and i'll be fine for the summer. I did some tricks, did a couple of wide open runs, and on the last run it died. No noises or anything just a quick slow down and stall, then wouldn't start. I assumed the battery died from the earlier stalling I was having. I got towed and brought it home. It mimicks the exact signs of a bad battery but the batt is new and tested fine. Each time I try it, the 'maint' warning flashes and it cranks very slowly several times as if it doesnt have enough voltage then just beeps. Its totally drivin me nuts as its the exact same as a weak or dead batt, when I know the battery is fine. I tried jumping it and got the same results, just turns over very weak and slowly for a few min til it gives up and beeps. The impeller is free of any debris or blockages.
I was supposed to be taking the wife out the day after my 'test run' and thats not happening now and shes upset. Ugh! lol... Any help you guys can give would be appreciated greatly and i'll answer any questions you have to try and troubleshoot this, saving my investment!! I noticed a post on here from <slipperywhenwet> with similar issues and someone mentioned a bad starter?
