I have a 2003 SeaDoo Speedster V6 240EFI. The boat was sitting for about 5 years and before I took the boat out on the water this year, I replaced the alternator, belt, spark plugs, radio, speakers, bilge pump and changed the gear oil in the jet pump assembly.
When I took the boat out the for the first time, the boat didn't run that well. The boat would bog down when you tried to give it throttle and it didn't sound like it was idling well either. I did some research (on here) and found out that the fuel filters probably needed to be changed. (I know, amateur mistake) Once I put new fuel filters on, I took the boat out again and the boat ran so much better. The boat was idling perfect and responded better to the throttle. The only problem now is that the boat would not go past half throttle.
I did some more research (on here) and found out that the Cylinder head sensors apparently go bad for no reason on this motor and if your sensors are bad, the computer on the boat will think that the boat is over heating and limit your RPM's to around 3500-4000. (which is consistent with the half throttle problem) I just replaced the sensors and just to make sure that nothing was blocking the fuel line I replaced the fuel line filter one more time but unfortunately I still can't go past half throttle. The weird thing is that if I stop the boat and then start it up and quickly give it throttle, I can go almost full throttle and it seems like there is nothing wrong with the boat and performs great. BUT, as you drive it, it slowly goes back to the point where you can't go past half throttle again.
Please help. I'm not sure what else there is to do. Is there a heat sensor that I'm missing and need to replace?
Thanks.
Thanks.
