Marc 123
any help would be appreciated…
i just took my 1998 seadoo GSX limited with the 951 out and noticed that the rubber was melting/smoking that connects the exhaust to the water box…
I took it home and hooked it up to a hose and noticed it was dripping water at the top of the water box.
I replaced the bellow, the bottom rubber piece that is connected with a clamp, becuase it had a pen size hole in it and put it back together along with blowing all the water lines out becuase I did see a small rock inside of the water pressure regulator housing and noticed that only one pee hole (back of ski where tow hook is) was releasing water…
now that it is all back together, it is still dripping from the top of the water pressure regulator housing, similar to what is was doing prior to replacing the bellow, and water is only coming out of one pee hole.
Does anyone have a clue on what might be causing the water pressure regulator to leak? Is there a certain way the water pressure regulator needs to be installed? I screwed it back together all the way in and I have tried doing it 3.5 turns and It still leaks water…. Fast drip.
I have provided pictures of how it looks now that it is replaced and how the housing looks.
thank you everyone for reading!
