rsatina2002
I just bought this 2001 Sea doo Challenger with Mercury M2 240 2001 engine. I bought it very cheap and the owner said he didn't use the boat for 6 years, and the boat was just in his friend's house and he move in to Florida and boat cover was rip and boat was exposed to sun and rain but engine was covered. I try starting it myself after buying 2 marine batteries, It doesn't start the engine. I hired a mechanic, he check the spark plugs, ignition and the compression on each valve and said everything is working.... he went to fuel pump and check everything there, and found out no ground firing from the ECM during On position on the (-) terminal on electric fuel pump and upon testing and bypassing it fuel goes right in to the pump primer with good pressure... He suspect, the ECM is not giving some power to the fuel pump during engine starts and needs to do more testing with ECM to check for faulty wiring since it has been a long time since the boat has not been used. Please help me to solve this problem and I know ECM won't failed that fast but I think maybe some vapor separator sensor or other problems that let the ECM not fired to the electronic fuel pump, that's why boat is not getting any fuel in. Thanks for your help in advance.
