[/B][/B]does any one know what the 2 black boxes are that are by the driveshaft and has a water line going to each one of them from the jet pump and can i disconnect them
why in the world would you want to disconnect your syphon tubes? they are ment to keep water out of your hull at high speeds the jet pump puts a sucking on them and it sucks the water out of your hull, leave them alone.
If you disconnect the lines your seadoo will fill up with water and have no way to get it out, when the water comes in from waves jumping and such. These 2 lines work as a siphon effect and bail out the water. They are called Bailer lines. Leave them in tact and be sure the hoses aren't plugged.
