please help cranking but wont start plugs soaked in fuel speedtser 200 430hp
speedsterboy
speedster200 430hp 2006 been stored for months just pulled it out and one of my engines stoppped starting i pulled the spark plugs out and they were soaked with fuel anyone got any ideas........... thanks
Are you sure the plugs were soaked in fuel or could they have been wet from water? Leaking intercooler is a possibility. Was the engine flooded with water by improperly flushing it? Does anything shoot out of cylinders when you crank it with the plugs out and throttle held open in drown mode?
Are you getting spark from all the plugs? May also want to do a compression test too.
If you truly suspect you have a fuel injector issue, pull the rail out and observe how they spray when cranking the engine. Here is a good troubleshoot video from one of our members, may help out some:
https://www.youtube.com/watch?v=IAGQA3LGdzE
Post back after you check these things out and give us some more info, we'll do our best to help you out.
Check for spark, check compression, pull plugs and crank to see if water shoots out.
