Previous similar thread locked, this is restarting that thread if OK.
I reviewed the earlier threads, but my issue is slightly different as part of the red plastic tube is now in my crankcase . . .
Was fogging my 1997 GTX for winter, the red plastic extension tube from my lube can popped off into one cylinder.
Tried removing, but appears while rotating shaft, part of the plastic tube got cut off (piston skirt?) and dropped into the crankcase, the rest of it (about 2") stayed in the cylinder.
Have tried several things to catch the piece in the cylinder, no success yet, but I WILL get that piece out before we re-start in the spring.
My concern now is whether the 3-4" long piece of this red plastic tube can cause any problems inside the crankcase and whether I need to pull the engine to remove it before I start the unit next spring, or whether it will just sink down to the bottom of the crankcase and stay there for the duration.
In earlier threads, this has happened to others in the past, not sure if anyone ended up cutting the tube as in my case, but figured I'd tap this group to see whether this is a problem or not to leave the piece in the crankcase.
Thanks for any help,
Chas
Chas
