The 787 engine in my 1997 GTX stopped turning over a while back. I initially suspected the battery, which turned out to be good. Then I hoped it was the battery cables, which turned out to be good. Then I hoped it was the starter, which turned out to be good. Finally I realized that the engine simply could not turn over. Something was preventing the drive shaft from turning and it was not debris in the impeller. Here is a YouTube video showing the problem:
https://www.youtube.com/watch?v=7HlkzUwkGFY
I finally faced the fact that I needed to take the engine apart to find the cause of the problem. I'm very inexperienced in any kind of engine work but with the help of the Shop Manual and plenty of time I finally got to the point that the cylinders were removed. What I saw was not good. Not good at all:
Here's a closeup of the broken piston:
So, there you go. That piston has broken and the "missing" pieces are down in the crankcase and preventing things from turning.
My question for the group is what is the most likely cause of this? Obviously a lack of lubrication? Could that have come from one carb being plugged? Is there a clue in the difference in color between the two pistons? The right one is dark and sooty. The left one is clean/white. Could the left one have been running lean or perhaps getting no fuel/oil at all?
Thanks,
Mike
Thanks,
Mike
