Perol leak causes big bang.
D 5UPE
Premium Member
Premium Member
Just to let you know im fine, but now looking for parts new or old for my 3D di.
I had a little mishap last Sunday when jumping waves in the North Sea.
While getting turned over with a big wave i righted my Ski and pushed in to shallow water.
And on pushing the starter and the ski not having non of it, I gave it another push. Bang it went with bits floating all around me.
It threw me into the sea and shook me up pretty bad.
On inspection it has demolished the engine hood and seat locking knuckle.
It has also split top half of hull from botom.
But before anyone goes blaming Seadoo. Dont!
You see I had a very exensive fix some months ago on a fuel problem.
Water in the tank and poor flow on the fuel pump.
I tried to remedy the water in the fuel tank buy placeing a water catch bottle
inside the hull.
This worked a treat and collected fuel and sea water every outing
What had happened was while jumping waves the water catcher had come adrift and left fuel in the hull.
On pressing the starter it ignited somehow.
I see the inlet manifold does not have a spar arrester fitted on these, and think a backfire set it off.
But with the rotary valve in these engines I dont see thats possible.
Another possibility could be a spark from the HT leads. But not sure.
Anyhow the ski is out of action till I source a few parts.
See in Sale and wanted section.
http://www.seadooforum.com/showthread.php?t=12200
Glad your o.k....!
Wow Dave, just glad to hear your o.k....that would have made me mess in my pants!....
This was an accident waiting to happen. The Seadoo's vent all flammable/combustable vapors outside the hull, to keep this from happening. Your "McGyver" fix sounds like it is the fuel source for the explosion but as to the spark that set it off, that was your solenoid. When the hull fills with the vapor of fuel, any component with an electrical contact is going to initiate the explosion.
Just really glad to see your o.k............:hurray:
Cheers Mate.
Yeah it was a close call.
The hull is a easy fix I think. Im not sure whats used to bond the two together though?
The rivets have poped and smashed the bumper trim also.
Parts are available through Seadoo Wharehouse which is a good find on here.
I found an earth wire that has disconectd itself from the coil so needs anew conector fitted to the end of the wiring harness.
Its a goo job I was standing alongside the ski in the water, as sitting on it would have launched me upwards. And damaged my tickle tackle :ack::rofl:
Ive been out of work now for 19 weeks so the repairs been put on the back burner for now.:(
