Performance boats using old technology
Hello,
I know this is and always will be a personal choice but why does everyone seem to always recommend copper top spark plugs as a standard replacement. I recently purchased a 2010 Challenger 210SE with a pair of standard 155's (I hate premium gas prices) both having about 222hrs on each one. When I went to check out the boat the first time the owner started the engines for me. It seem to take 8 to 10 seconds for each engine to startup, which frankly bothered me. I mean there's only 3 pistons per engine, right? It's not that they were slow to turn over (weak battery or starter going bad) just seem too long to me but once started ran fine, no smoke of any color.
I purchased the boat but only after having it surveyed first as this was my first boat and not knowing what to look for as way of fiberglass. When I got it home, I looked through his service records, which he gave me, all being done as per the owners manual stated, except for oil and spark plugs which were done every 50hrs. That got me to thinking and quick glance to the NGK website. Copper tops were 4339 (DCPR8E) gap .028 and Iridium 6546 (DCPR8EIX) gap .028. Accordingly the owners manual says change plugs at 200hrs or 2 years. Well the previous owner did it every 50hrs, standard copper tops and recommended oil, oh well his money.
Long story short, I put the Iridium's in (the label next to the engine cover said spark plug gap .030) so I set them all to that, connected a garden hose, Cranked the starboard engine, fired up in less than 2 seconds, put the water to it, ran smoothly for 30 seconds, shut water off, then engine. Port engine started the same way. Took it out for the first time the following weekend in the St John's river, both engines fired up in less than 2 seconds each, very smooth. Water was almost like glass smooth, had three other people with me and got into the channel, pushed both engines to the firewall. It settled at 48 on the speedo and verified on the gps (iPhone and boat) as the same. Ran around at 30 to 35 mph for five hours and only used half a tank. I don't know if that's good or bad being my first time out but what a blast it was, sorry I waited so long to get one, thank you Sea Doo!!
Through all my years of working on all my vehicles, including a couple of motorcycles and now a boat and researching the benefits of using Platinum or Iridium spark plugs both for performance and fuel economy, I honestly don't understand why copper top plugs are still available, again just my choice!!
These 4tec motors are very picky about plugs. I'd bet a fresh set of OEM plugs would have yielded similar results.
Plugs should be changed annually. They're cheap and easy to replace.
We've had our 2012 210SE with the twin supercharged motors for 5 years now and never had an issue with the OEM plugs.
Glad you're enjoying your new boat.
Congrats.
I suspect the slow starting could have been from stale gasoline or some carbon build up on the plugs especially if the boat wasn't run in a while. Did you try to restart them a second time? I've never seen or read SeaDoo to recommend any other type of plug for their 1503 4-TEC engines. It's what's in the owners manual and to most of us on this site it's the bible.
The metals in the spark plug simply pass electricity from the coil to the tip to create a spark. Copper has a more stable performance over iridium or platinum as these other metals are not as conductive and may cause plugs to overheat especially considering that we run these engines at 6,000 to 7500 RPM's for hours at a time. Not something you would do with a car, motorcycle or other vehicle. These new spark plug metals were developed more-so to allow cars and trucks to run up to 160,000 km's before needing a tune up and plug change.
I run my copper plugs for 2-3 seasons (depending on how much I run the boat), and simply clean and gap them when I winterize the boat, then put fresh ones every 3 years.
I would be curious to know how the iridium plugs perform and look after a full season of use. Heck I may even try them!
Happy Boating, the 210SE is an awesome boat and the twin 155's are solid engines.
The 4Tecs are finicky about plugs. The OEM ones are cheap and should be replaced annually. I believe they run about $15 per set of 3.
Cheap maintenance when it comes to having a happy 4Tec. Always good practice to keep some spares on hand just in case.
