pee line just a weak trickle at the dock?
1800chall_tim
i might just be me but i do think that the pee line/indicator under the tow ring had a stronger flow rate last season than this year. and when i run each engine one at a time on the hose the pee line has a much better flow than while in the water with both engines running. what creates the pressure to the pee line? both engines are circulating water and i can't feel any hot spots like there is a blockage. should i be concerned or is this common? thanks, Tim
They will get clogged up, try blowing some compressed air through the lines.
Lou
There is not much flow at idle, it's not like a ski that will stream. That cover plate really diffuses the flow. Just as long as your cool to the touch everywhere, the water coming from the plate should be warmish.
