dblackstone
After getting screwed out of a deal made on memorial day weekend I kept watching Craigslist and this 2005 well taken care of Islandia showed up on Craigslist, 7 hours away but got it for a great deal. Strong motor, redone seats but needs a good buff and wax on the hull. Plus it came with 2017 Aluminum I Frame Trailer.
List to do:
Wax and possibly wet sand lower half due to sun fade of color.
Waterproof Mooring Cover and Bimini Top
Change out Drawer Latch due to broken Spring
New Todd Plastic table
New oil tank as oil level sensor has failed and cleaned all oil filters
Change water filter on Fuel Line
Try to get Speedo and fuel gauge to work - Fuel Gauge now working, not worried about Speedo
Re rivit 2 of pop up sun seats on motor cover
Try to get fresh water pump to work or replace it
Add fuse in the Bilge pump that is wired directly to Battery 2
New Rocker switches as rubber is gone on most of existing ones, or just covers https://newwiremarine.com/marine-grade-switches/
Replace a couple bulbs in interior lighting - changed to white led
Replace engine cover rods as one is weak - ordered
Tighten engine hinges to cover. Hinge bracket was actually broken thru fiberglass as they had wrong rods
Re Silicone Fountain Drain.
Cupholder for Captains seat
Replace White vinyl blower hoses in Engine Compartment
glue in Carpet in Table storage area - glued in part of it
Change out brown handles for white ones or black ones
Get new fish finder/GPS (all set up an wired with transducer but unit was supposedly stolen)
Fix trailer wiring plug, change out trailer light that was replaced with cheap one
Debating with wife over hydro turf so we aren't always washing down the foot prints on the white floor
Fix Ride Plate as screws are stripped Added Nauticus Smart Trim Tabs and made the boat handle awesome!!
More to add to list I'm sure
List to do:
