Hey Aaron,
Checking the pump grease is pretty easy, you need to remove the reverse bucket, steering nozzle, and the venturi to get at the three screws holding the nose cone on. Once you take it off, if everything looks good, just button it back up. There is no need to add any grease as long as it is not contaminated with water or rust. If you do find contamination then it is time to pull the pump, take it apart and probably rebuild. I had to have this done when I got mine a few years back.
If you have not already, I would suggest downloading the shop manual and reading up on everything before you dive in. As I recall, you will need some thread lock and silicone sealant to put everything back together. I think it called for blue thread lock on all the screws/bolts that come off the pump, and a type of silicone that goes on the mating surface between the pump and venturi. You will also need a good set of hex keys to take off all the screws/bolts on the propulsion system and a torx socket for the oil change.
I’m excited about spring myself, although probably won’t get our boats from storage until mid May. By the way, I am from the Crete area just a bit east of you. I mainly keep the boat up at our cottage in Michigan. Since we are on a lake, I just put it in late may and take it out in September. Don’t do a whole lot of traveling with the boat, although I have thought about it.
Good luck with all the pre-season maintenance. Feel free to PM me if you have any other questions, I can give you my personal e-mail/phone and would be happy to help out. The first time with all these maintenance tasks can be a bit daunting, but if you take your time and do the research first you'll be a pro in no time. Plus it's a good excuse to buy some cool new tools....
--Deven
