P0351 P0353 P0562
b_matt_10
Hello I have a 03 Sea doo gtx supercharged. I am somewhat mechanical inclined enough to replace and work on it but I am still unable to figure out why it is throwing three codes. P0351 P0353 P0562 two ignition coil codes and a low voltage code. I’ve tried replacing and switching ignition coils, Sent the ecu out to be re flashed replaced the wiring harness that runs to coils ect. One fuse was blown regarding to ignition coils but since then replaced and still same problem. Anyone have any ideas on what else could be wrong or would need fixing? Other wiring harness, voltage regulator, oil pressure sensor?
