P0326 - Knock Sensor out of range - Long History
ethante
I have a Seadoo wake pro 215 from 2009 - 151 hours, and having problems regarding the knock sensor (P0326), I got a original B.U.D.S tester on it and are having the info: knock sensor out of range this is only showing when I go above 6000-7000 RPM.
What i have done so far:
  1. Removed the old knock sensor and clean the surface
  2. Installed a brand new Knock sensor - Tested it (Same Error code)
  3. Gave all connector contact spray - Tested it (Same Error code)
  4. Installed a new Harness - Tested it (Same Error code)
  5. Tested the ecu with an identically one from my brothers same model and year, that are working, where I changed the cluster as well, same result (Same Error code)
  6. 3 x new spark plugs
  7. New Oil and filter
  8. Checked the engine mount, if it was loose, it is so fine
  9. Looked for places where things was loose, and it is all steady.
All torque to the right "nm" amount from manual.
clearing this code, is done by removing the key.
what can more be the issue, something regarding the exhust or something else inside the motor, i have no clue any more.
I do not know what to do any more, please, a good soul, help me in the right direction.
