you can get the manual from the candoo site when you register or from here. i assume you have the 4tec?
just make sure you clear the fault from the ecu with the candoo. check fault status (follow the prompts to write to the ecu).
candoo system;
Fault Code:
The fault codes are special codes assigned to particular problems. More information about the fault codes can be found in the Service Manual.
Source:
The Source tells you which component is sensing the problem.
The 4-TEC Fault system has two fault states:
Active
Occurred
Active Faults
"Active" means that the fault is currently happening now; the underlying problem causing the fault still exists and must be fixed.
Occurred Faults
"Occurred" means that a fault became active at some time in the past, but at this moment, it is not active.
Count
The first time the system detects a fault, it adds the fault to the list (if not already there), and increments the fault counter by one. Note that it only adds one per each time the system has been powered up. For example, it may detect a fault 20 times during a ride, but it only adds one to the count during the entire time the watercraft has been running. Next time the watercraft is powered up and has the fault, it will add one more to the counter. Note that not all faults will have a count.
from the 4tec manual;
Dynamic Test
To check the operation of the thermostat, put it
in water and heat water. Look inside the cylinder
head return hose connection to see the movement
of the thermostat. Thermostat should open
when water temperature reaches 87°C (188°F).
If there is no operation, replace the coolant pump.
