Hey team.
My name's dave. New to the forum and new to JetSki's.
I apologize in advance for a fairly lengthy post. Ive scoured the internet high and low and cannot find and answer to my problem.
Im a long time boater, and long time car enthusiast. Ive rebuild many car engine (in fact full car restorations) in the past, and recently decided to try a jetski.
I bought an 09 RST IS 255 that needed a full engine rebuild. Not sure about the history, just that it needed a rebuild. I had to bored .5mm from each bore (and fit oversized pistons etc).
But........moving along. I got the ski fully rebuilt, and took it for its maiden voyage about a week ago. To my amazement (because theres usually at least a water leak from a full rebuild!), the ski performed flawlessly. Not one error, not one miss. I didn't ride it hard at all. Gave it a few little squirts to about 5000rpm, and that's as hard as I went. The ride lasted for about 2 hours at which point I took it home, rinsed it out, and parked it in the garage.
I left it there for about 4 days, and then went out into the garage to start it. Would you believe it, I couldn't find the key anywhere!. So, I headed off to buy a new one. Brought it home and using buds (which I have) coded it up to the ski. No issues there.
I started the ski, and the RPM's jumped to about 3500. They sat there for about 7-8 seconds, before starting to settle back down (this seemed a little longer than normal). When the RPM's did settle down, the ski start coughing and spluttering. It didn't stall, but wasn't happy at all. At that point, the check engine light came on, and I got the P0106 error (Manifold pressure sensor out of range).
From here forward, its been a NIGHTMARE!. Below are my findings so far.
1) I found that it actually had a leaking intercooler. I bought a new one and fitted it.
2) I purchased a new MAP sensor and fitted it.
3) I removed the inlet manifold to ensure there was no water or residue left in it. It was a little dirty inside. I cleaned it up, dried it out, and refitted it.
4) I visually inspected the inlet manifold to ensure no cracks etc.
5) I changed the throttle body over to another working one I have (and using buds, reset the TB position).
6) I have confirmed that PIN3 (the analog voltage pin) on the MAP sensor, is outputting voltage at idle of about 1.6volts. A rev of the engine sees the voltage increase slightly, but obviously the load I can apply is limited.
7) I have disconnected both the TOPS and TAS sensors (which share the same5V feed as the MAP sensor) to ensure no overloaded current draw from those other sensors.
8) For shits and giggles, I put in new spark plugs and oil filter.
9) I have checked the fuse box to ensure everything is seated correctly with no loose connections.
10) I have remove each and every plug in the ski and cleaned with contact cleaner.
The oil is fine and not milky at all.
The symptoms are exactly the same each time I start the ski, with one small exception. When cold, the time it takes from the idle settling, to throwing the code and running rough seems to be a little longer (IE: when its warm, it settles straight into rough idling, whereas when its cold, it idles OK for about 5 seconds, then turns rough).
On the odd occasion, AFTER the code has been thrown, if I give the ski a rev, the check engine light will turn off, and the ski will rev quite freely. As soon as I let it come back down to idle, the code pops back up, and it runs rough again.
Im at a brick wall here guys. Im hoping someone can help out here and point me in the right direction as to what may be wrong. Melbourne is seeing some awesome weather at the moment, and the kids are super bummed!.
Thanks very much to anyone in advance that may be able to help.
Dave
Dave
