P* GTX LTD rave/pressure reg adjustments
Grim
I noticed there is a red adjustment knob on the rave valves and the pressure regulator. When do you need to adjust those and why?
I just keep the red valve level/even with top,,,the only way for you tell the difference would be to go side by side with someone you ride with,,,do a before,,,and after,,,unless of course you have a graphing radar gun that the factory race teams have,
You should not have to adjust those if they are set according to the manual. What those settings are might be specific to each machine.
The water regulator I can't comment on. But the rave valve adjustments are something that people ride sleds and are changing clutching, carb settings and elevation a bunch. Not something a stock Sea-Doo needs to be messed with.
THere is no harm in messing with the ones on the engine, just make sure they are both set the same and play with it because you can't hurt anything.
Don't mess with the one on the waterbox as I have never been able to find what the stock setting should be.
