I recently bought a 2015 Sea Doo Wake Pro 215. I also have a 2012 Sea Doo GTI 130 SE. I changed the oil in both at same time. Starting with the GTI 130 SE. They were both on same trailer. Checked the oil in both before starting. The Wake Pro appeared to be a quart or so low on the dipstick. When extracting the oil, I removed approximately 3 quarts from the GTI 130 SE. I did measure it with a half gallon milk jug and a large glass measuring container. Then extracted the oil from the Wake Pro 215 and only got just short of 2 quarts of oil. I tried several times to get more oil out without luck.
First of all, if only 2 quarts of oil were added at last oil change instead of 3 quarts at 62 hours, now the Wake Pro has 82 hours on it, would any damage to engine be done? If so, what type of damage could have been done? I did a compression check before buying it and all cylinders were within 10%. I have seen on you tube that this is acceptable. I thought, I also checked the oil before putting it in the water and seemed to be ok. I bought it mid September and haven't had it in the water since. Is it likely, that no damage was done by running it with only 2 quarts of oil, instead of 3?
The other scenario is, if the oil was added correctly at 3 quarts at last oil change, what happened to the oil? There was not any water in the oil, which would suggest a head gasket leak. This suggests that it is either burning oil or the correct amount of oil was not added at last oil change.
Any suggestions would be appreciated, especially if you are a pwc technician.
