check your fuel water seperator filter if you have one if you dont then your asking for $$$ problems . this motor should have a VST tank ' vapor seperator tank .on the side of the engine . it will have a hand full of fuel lines and a wire or two going in it . it houses the high pressure fuel pump , the hp pump has a very fine mesh filter on it . they do require cleaning or replacing time to time , they may look clean but there not . it may look like a coplicated task but take your time and study it . it will have about 8 phillips head screws hold the top on the tank , it has a o-ring up there and it may stretch upon removal but i will get to that fix . you have some crimped hose clamps on there , dont cut them if you take a screw driver you can pop the hoses off and back on with out removing the clamp . once you have the tank off and apart twist the filter on the bottom and it will come off ,take your favortie brew of carb cleaner and go to town , blow thru with your mouth before and after and you will see the difference . also clean out your tank while its off . as for the o-ring if its stretched way beyond use the lay it in the groove of the tank and on the straight long side cut it , finish laying what you can in there and super glue helps big time with this , and when you get to where you excess is cut it just a mm or so beyond what you need and glue it in place , it will not leak . your fuel filter on this motor can not be neglected . pm me for a phone number and i can walk you thru the steps .:cheers:
