Hello,
Just bought my first Sea Doo boat. A 2003 Utopia 185 with the 200hp Optimax. Great condition and a good deal but it does have what I hope is only a bad sensor or two. This engine is the Optimax with the pressurized oil tanks. Ive done a lot of digging, and did find a lot of useful information on here, but much information is not specific to the Optimax. The EFI seems to be a whole different animal when it comes sub systems like the warning system, fuel system, and oil system compared to the DFI Optimax.
What manual are you Optimax Owners using? I found the M2 manual on this website, but that seems to be for the 210 carb model, not the Optimax. I did find this manual on a different website that seems perfect, but I cant download without paying them t0o. If its the correct one, I will.
http://www.scribd.com/doc/93986834/8369382-Mercury-Mariner-200hp-Optimax-Jet-Drive-Service-Manual
200hp Optimax Warning Horns. Does anyone have a good list of the warning horns for the Optimax? Im getting the four beeps a minute horn before I start the engine... and the long steady horn after its been running at high rpm. Im going to top off the small oil tank today to ensure it has no air pockets, and make sure both oil caps are tight since it is pressurized. I do see the oil sensor on the small tank and hope that is it. I will also drain the water/fuel separator on the lower port side.
I also put 163 F thermostick marks on the cylinder heads to check for high temperatures, so far they have not melted.
Thank you and have a safe weekend.
S/F
Jeff
S/F
Jeff
