Optimax 200 Spark Plugs Replacement
sam22mac
Are there any tips or tricks to replacing the spark plugs on 2004 200hp optimax. I heard they are not easy to get to.
No trick. BUT..... I use a sparkplug socket with a hex on the end. Then... I use either a ratchet, or an open end wrench to turn them out. (whatever I have room for)
I don't think you should need to remove the expansion chamber.
I know on the Opti, it's a tight fit... but you should be able to do it.
