hey all,
Welp i got both ski's on the water this weekend.
The 98 GTX runs flawless!!! The XP is where i am having problems.
background:
I have replaced all fuel lines, carb filters and main filter.
I cleaned out selector switch.
It was running great the beginning of the day for an hour or 2 straight.
Then it started missing. I pulled the plugs and the front cyl. was brown and dry. The rear cyl. was wet with gas.
I decided to try and lean the rear carb with the low speed screw. i went a 1/4 turn in and ran it around, same problem. I did this a couple of times till it was 3/4 turns out and decided that anymore didnt seem right. So i turned it back to stock setting of 1 1/2 and same thing. I also went the other way to richen it up, same thing still.
I would assume the high speed screws are at 0 because i did not turn them when i took them apart, This ski has never had the carbs taken off until i removed them.
So my questions:
I rebuilt these carbs, do you think that they have clogged the carb filters already? or is it something else.
The ski will not go faster than 5500 rpm and not over 40 - 45 mph
Another thing i noticed that after an hour or 2 of riding there was the green crap from the old lines in the bottom of the main fuel filter. could this be from inside sending unit?
Thanks for the help as usual!! :cheers:
background:
So my questions:
